Ga door naar hoofdinhoud
Support for tablets by Coby, including the Kyros line.
75 Vragen Bekijk alle
Where can I find a replacement battery?
My daughter's tablet, a Coby MID-7036 will not power on and not charge. I have it taken apart and see the battery connector is soldered onto the motherboard. I can de-solder it or snip and strip the wires to connect a new battery but I can't find a replacement battery anywhere. Any ideas where else I can look or is there a way to use a battery with similar dimensions and capacity?
Is dit een goede vraag?
Score 5
Voeg een opmerking toe
Android Fix Kits
Slechts één reparatie scheidt jou van een nieuw scherm of een nieuwe batterij.
Nu winkelen
Android Fix Kits
Nu winkelen
1 Antwoord
Het nuttigste antwoord
I was able to search the s/n on the battery case itself and found a replacement on Ebay. I sniped the wires off the old battery and soldered the ends to the new battery and used heat shrink tubing to cover everything up. Device charged up and is good to use.
Was dit antwoord nuttig?
Score 2
Commentaar:
Hi Brian
I thank you for the advise.
How much was the battery and how Long did you wait to receive the battery
Thanks
by
It was $8.00 US and took about 7 days
http://www.ebay.com/itm/3-7V-2400-mAh-Po...
by
Voeg je antwoord toe
PolishRifle zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 3
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 8
Altijd: 968
