iPaq does not reconize A Battery
Will Work if plugged into power supply, but will not work on batt along. Any ideas?
jdeguire@juno.com
Is dit een goede vraag?
jdeguire@juno.com
it sounds like a dead battery
but you didn't provide that much information - is the installed battery old or new?
Was dit antwoord nuttig?
Thank You for your responce! Battery IS New! We have tried several Batteries and None work. It does work if It Is Plugged In to the Power source. But does Not reconize any battery in it.
JOhn
there's a small limited travel micro-switch on the mainboard that makes contact with the small nipple under the battery compartment cover ...
check the case has been screwed down properly and the nipple hasn't been broken off ...
you could gently insert a paper-clip into the micro-switch hole to test if this cures your problem :)
JOhn
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 1,258
