How to look after new battery
What is the best way to maintain a new battery so it will last longer.
I have replaced my battery with a 5200
( mAh )battery.
Cheers john thornton.
Is dit een goede vraag?
( mAh )battery.
Store it half-charged when you store it long term.
If you want to store your device long term, two key factors will affect the overall health of your battery: the environmental temperature and the percentage of charge on the battery when it’s powered down for storage. Therefore, we recommend the following:
Do not fully charge or fully discharge your device’s battery — charge it to around 50%. If you store a device when its battery is fully discharged, the battery could fall into a deep discharge state, which renders it incapable of holding a charge. Conversely, if you store it fully charged for an extended period of time, the battery may lose some capacity, leading to shorter battery life.
Power down the device to avoid additional battery use.
Place your device in a cool, moisture-free environment that’s less than 90° F (32° C).
If you plan to store your device for longer than six months, charge it to 50% every six months.
Optimize your settings.
Energy. The Energy Saver preference pane includes several settings that determine power levels for your MacBook. Your MacBook knows when it’s plugged in and runs accordingly. When using battery power, it dims the screen and uses other components sparingly. If you change this setting to maximize performance, your battery will drain more quickly.
Brightness. Dim the screen to the lowest comfortable level to achieve maximum battery life. For instance, when watching a video on an airplane, you may not need full brightness if the cabin lights are off.
Wi-Fi. Wi-Fi consumes power, even if you are not using it to connect to a network. You can turn it off in the Wi-Fi status menu in the menu bar or in Network preferences.
Applications and peripherals. Disconnect peripherals and quit applications not in use. Eject an SD card if you’re not currently accessing it.
Plug in and power on your MacBook to charge other devices.
Make sure your MacBook is plugged in and powered on when you’re using it to charge other devices via USB. Otherwise those devices may drain the battery in your MacBook faster than normal. If another device is connected to your MacBook when it’s turned off or in sleep or standby mode, the device’s battery may drain.
Was dit antwoord nuttig?
Don't overcharge it! That is a common problem people constantly overcharge their laptops. Also don't charge and use it. Technically use it while it is not charging. You can do this for the first few weeks but then you should be fine to do it. Also don't use it and the second it is low then charge it then use it then charge it. Basically give it a break after a while. Have it dead for a while it will be fine.
Can you back up with reputable links, anything you said here?
you can totally charge when you are using it, just unplug when you are at 100%
No but common sense would tell you these things. You can definitley find information on what I said floating in the internet.
This user won't accept your answer he actually accepts then constantly un- accept
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 138
1 Opmerking
why did you unaccepted my answer?
do you need help answer anything else?
door Sunny
