Ga door naar hoofdinhoud
Reparatiehandleidingen, demontage- en Probleemoplossingsinformatie voor de tweede generatie Apple iPad met CDMA 3G-mobiel netwerk (Verizon), verkrijgbaar met 16, 32 of 64 GB opslagruimte. Bevat een dual-core processor van het type A5. Uitgebracht in maart 2011. Te herkennen aan modelnummer A1397. Voor reparaties is het gebruik van warmte en voorzichtig wrikken vereist.
Changed screen, will not power up or connect to computer
I've changed the screen on my iPad2 the tried to test to make sure it works before sealing but it won't turn on using power button.
When I connect it to a power source (not computer) the Apple logo appears then goes, this continues to happen in a loop. Nothing else happens.
When I connect it to the computer the screen stays black. It doesn't appear as a device on the computer and the Apple logo doesn't appear.
Can anyone help
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Filteren op:
Gekozen oplossing
I am not sure what could have gone wrong here.
But if I am to troubleshoot such an iPad, I'd start first by resetting the iPad: unscrew the board, wedge a plastic card underneath the logic board next to the the battery connector, and lift slightly to make the battery disconnect. Re-screw everything, disconnect the charging dock, clean the connector on the board, reseat the charging dock, and leave the iPad to charge for 20 minutes, and see if it gets back to life.
This way I would have reset the iPad and ruled out a loose charging dock.
If reseating the charging dock does not help, I disconnect the PMV (Power-Mute-Volume control cable) from the board and try again (start the iPad by connecting it to a charger).
Then I'd try a new charging dock.
If that still doesn't help, I examine the apparent parts of the board, looking for pry damage such as broken components, part or completely torn off the board.
If the iPad restarts normally at some point, but still doesn't respond to the Power Button being pressed, then it could be that you tore the PMV cable when separating the glass. Examine it carefully. It has 2 parts that run through the aluminum frame on the top right corner. Are they part or completely torn, or some piece missing?
These are speculations, but you have to start somewhere, and this is assuming that the iPad had only a broken glass, no liquid damage, and worked perfectly before the attempted repair. If not, let us know its history.
Good luck..
Was dit antwoord nuttig?
Score 1
It's software problem. Your Ipod is running in loop boot.
Voeg je antwoord toe
Richard Watson zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 7
Afgelopen 30 dagen: 22
Altijd: 463
