Screen repair, purple line and now error 53
Ive broken my iPhone 6 screen and replaced it with a new one. I definitely kept my original home button in place.
Upon turning the phone on Im getting purple around the edging of screen and a very small fine line vertically down the screen. It is purple on black and green on other colours, very very fine line...
I thought maybe cable wasn't in right but I've tried all four of the cables going from display to mainboard.
Ive disconnected battery aswell and have tried to do a restore and now my iPhone is stuck in recovery mode giving me error 53. This seems to be related to the touch id but my fingerprint scanner was working fine before.
Another issue is getting the screen to slot in right, its slightly raised up at the home button end, as if screen is too big for phone...
What should i do now, any way to fix these problems, can i revert back to the way my phone was on 8.3
Is dit een goede vraag?
6 opmerkingen
Any help...bit stuck here as phone was even revert to a working state...
door Aidan
where did you buy the screen from?
door Adam Kruszka
When I put the screen on the first time i had loads of purple lines so I popped the display data cable connector off and back on again and was better. Maybe this connector has been damaged and thats why one purple line remains..
Would this connector give error 53 if faulty....
door Aidan
Disconnect the screen cable, hold them level to your eyes. They should be flat. If they are "banana'd" outward (the smooth side of the connector is on the inside of the curve), bend them ever so gently until they are straight again or slightly bend inward (the connector should now be to the inside of the curve). I usually do this because the replacement screens have very thin connector that often bend when ben pressed in place or pried off.
door Rany
Got it going, all I had to do was disconnect home button connector and reinsert it. Im almost there. I still have a bit of a purple border around the edges, kind of faded. Ive checked connectors with magnifying glass and straightened out the first one that goes on as it was a little banana shaped. Still no good...
Also is there is any issues getting the display pushed on, I can't get the button half pushed in properly, screen is not nice and flush on the home button half on display but its all good at the top half...
door Aidan
1 commentaar meer tonen
