Ga door naar hoofdinhoud
Een gameconsole voor de televisie, geproduceerd door Sony Computer Entertainment, ook bekend als de PS4. Voor het eerst aangekondigd op 20 februari 2013 en gelanceerd op 15 november, 2013.
1695 Vragen Bekijk alle
Controller won't sync with console.
I've run into an issue with a few PS4's where the controller won't sync with them. I know the controller I'm using is good because I've used it on several different PS4's without issue. Has anyone had any luck fixing this issue?
Thanks
Is dit een goede vraag?
Score 2
2 opmerkingen
When I plug the controller in and I press the PS button the light on the controller flashes blue, but it never connects. The light will go back to orange and then just repeats the process when I press the PS button again.
door
this is literally happening to me too but i am inexperienced with welding or whatever you guys do so i cant really fix this
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
I managed to change the wireless communication chip on the motherboard and it fixed my problem. In this picture it is in the lower left hand corner covered by a white sticker and shield.
Was dit antwoord nuttig?
Score 1
5 opmerkingen:
So you must have reballed it by hand?
door
I didn't even reball it actually. There are only about 60 contacts on the back of the chip and they are spaced far enough apart to not have to reball. I just fluxed the back of the chip that I took from another PS4, put it into position, heated it and it worked like a charm.
door
Wow..crazy...I assumed you would have to reball it. Nice! Hopefully it lasts a long time!
door
Soooo.....? Success??
door
how am i an inexperienced 14 year old gonna fix this
door
Voeg je antwoord toe
RegencyTech zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 2
Afgelopen 7 dagen: 18
Afgelopen 30 dagen: 82
Altijd: 18,179
