Ga door naar hoofdinhoud
The Nexus 6 is an Android phone developed by Google and Motorola released in 2014 with a 6-inch display.
68 Vragen Bekijk alle
How can I get the charging port replaced?
how can i change my charging port on my nexus 6 ???
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
arthur1870, it is soldered to your motherboard. You will have to disassemble your phone, desolder the old one and then resolder a new connector.Not an easy task since the contacts on the port as very small. Unless of course you have the tools and skills to do that. Use these guides to work on your phone.
Was dit antwoord nuttig?
Score 3
This is the port you need: http://tinkersphere.com/electronic-compo...
Mine jiggled off since I connected and disconnected the cable so much. You need to desolder the old connector with solder wick and resolder the new one with a soldering iron.
Score 2
Voeg je antwoord toe
arthur1870 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 5,712
