Ga door naar hoofdinhoud
Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White. This page aims to help users troubleshoot, fix, and seek help for the iPhone 4.
2375 Vragen Bekijk alle
Vraag afgerond
Detach home button from ribbon cable
How do I detach the home button from the flex/ribbon cable?
Update
Thanks for the guide, but you se in the last image. How do I detach the button from the cable?
Is dit een goede vraag?
Voeg een opmerking toe
5 Antwoorden
It is depends of your device, see the tear down section and follow the instruction until the home button removed.
If you not familiar with this friendly-UI website, you can use the search box at the upper right corner, just write the device you have, and the result contains everything (repair manuals, teardowns, questions, etc).
Was dit antwoord nuttig?
4 opmerkingen:
This is the closest guide we have for that process, but we do not have a guide for separating the home button from ribbon cable.
door
Oh, I'm sorry, i think he just want to detach the home button from the phone.
door
Is it possible though?
door
Possibility always exist.
But I'm no expert, Markus is.
Try asking him.
door
Hope this isn't too late but it is very much possible. Using a small flat head screw driver, I worked around and then underneath the mechanism away from the button. It's just a mild adhesive holding itself to the button.
Won't prying the button off the ribbon cable damage the cable? Can you add low heat to it first?
It's basically a sticker. Just work slowly and carefully.
I were mess it up when trying to detach the flex cable from the plastic home button. Now it does not work. Maybe it is broken somewhere.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,576
