My computer only turns on with applied pressure, what's wrong?
My MacBook Pro does not turn on unless I apply lots of pressure on the right above the disc-drive. Before, I only had to apply pressure to turn it on and then it would stay on, now it does not stay on unless I apply consistent pressure above the disc-drive. Apple told me I had a faulty Logic Board and my warranty is expired. I feel as if there is some misplaced circuitry in my computer. What Step-by-step guide can I follow to fix my computer so that it can turn on? And what is wrong with my machine?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Commentaar:
Thanks guys but I am still wondering how moving the keyboard connection with the computer will help the computer turn on. Would somone mind to elaborate? Thanks.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
Ooit iets gerepareerd? Je bent een genie.
Deel je reparatie met #ImAGenius
We zijn allemaal genieën
3 Antwoorden
Gekozen oplossing
Try re-seating the keyboard to motherboard cable on the motherboard.
Heres how: MacBook Pro 15" Core 2 Duo Models A1226 and A1260 Keyboard Replacement
UPDATE also take a look at the solder connections on the Power On button and test with a multimeter.
Was dit antwoord nuttig?
Score 2
Commentaar:
agreed +
door
BTW, you dont need to follow the whole thing. just to the step, where it shows how to take the ribbon cable out... thats where you need to replug it...
Score 1
hey did you ever find a solution for this?
Voeg je antwoord toe
BrokenMacGuy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 1,246
