Repair guides and support for your Samsung TV.
1320 Vragen Bekijk alle
Red and green colors going out
The red and green colors are going out. Blue and yellow are fine. If I tilt the TV forward then back, the colors will come back in for a bit then go back out. I have a Samsung model LNT4042HX/XAA. What will fix it?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
2 Antwoorden
Gekozen oplossing
Changing inputs helped. Color still messed up on one input but not the other. So, all is good for the moment as long as color comes in good on one input.
Thanks for the help!
Harold
Was dit antwoord nuttig?
Have you tried every input in your tv to check if this simptom happens in all of the?
If the color failure persists in all of them, then you will problably have to buy a new controller board for your tv. If the problem only occurs in one input, then a rework of the solder joint of the connector will do the trick.
Voeg je antwoord toe
Harold zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 5
Afgelopen 30 Dagen: 24
Altijd: 692
