no charging no starting up
Nokia 1800 I played games,after few minutes i turned off it,removed battery then again replaced the battery and tried to turn on.But there was no response of it,even it could not charging.
Is dit een goede vraag?
atlasbd0913, start with a new battery. Make sure that you cable and charger are working. Make sure that the connector in not bend or has broken pins, clean it with some puffs of compressed air. If none of that works, it is possible that you are having logic board issues. For that you will have to disassemble your phone. then check the DC-in jack and the power fuse on your logic board. You will need a multimeter etc. to do that kind of work.
Was dit antwoord nuttig?
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 56
