caliper is leaking brake fluid
I changed the brake pads on my Nissan now the caliper is leaking brake fluid and the left rear hub leaks too, so the car looses the braking power I have to bleed the brakes almost every day to get it to brake.
Update
should I change the whole caliper or wat ?
Is dit een goede vraag?
2 opmerkingen
How did you bleed the brakes? What problems with your brakes are you having? What year is your Nissan?
door oldturkey03
How do I bleed the rear wheels ?
door sibusiso motha
