Ga door naar hoofdinhoud
A laptop by Toshiba with a 15.8" display and runs Windows. Has a straightforward repair similar to most laptops. Requires only a screwdriver.
5 Vragen Bekijk alle
K O'd my laptop
In a fit of rage and stupidity ,I slammed my laptop closed and now it is inoperable. I have a windows Vista factory out of the box recovery program but it will not recover. It will load first disc and second disc but 32% through the recovery it has an error and shuts laptop down. Do I need a replacement laptop along with anger management ? Lol
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Hi Ebert, While the machine is running, place your ear next to the machine and listen for any signs of hard drive failure. Provided you have a mechanical hard drive, sounds of spinning up, clicking/clunking and then spinning up again, etc. may be signs that you accidentally damaged the hard drive. A healthy mechanical hard drive has somewhat of a chattering/popping sound. Also--depending on just how hard it was slammed--It may be a good idea to 're-seat' the memory, as a poorly seated chip may become partly dislodged in the even of jarring. Start there, and please let us know how it goes.
Was dit antwoord nuttig?
Voeg je antwoord toe
Ebert Williams zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 4
Altijd: 258
