Ga door naar hoofdinhoud
Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Vragen Bekijk alle
Water damaged iPhone 6 - keeps "search" ing...
Hey,
My iPhone 6 fell down to the toilet and after I've dried it everything's work except the cellular network - it only tells "search"...
I've also tried to check for its IMEI number and it doesn't show up.
Any ideas? what can I do?
Thanks,
Nir
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Usually when the IMEI number is missing (and consequently cannot connect to the cellular network), then something like your baseband circuit or IC is damaged/shorted.
Your iPhone will need professional repair, with the proper cleaning and micro soldering tools and skills.
You will need to have your logic board removed from the phone, then the shields removed from the board.
Then starts the cleaning process: displace the water, clean the board using a professional ultrasonic machine, rinse, dry.
Then the repair process: replace/repair all apparently damaged components.
Then testing. In which case if something is still not working, the repair technician can look for the specific cause (and may not find it, or at least not in a timely and economical manner).
For this kind of professional approach, be prepared to pay 20% to 30% of the cost of a new device.
Or go to an Apple Store, and pay to have it replaced. I usually prefer repairing. But in case of massive liquid damage, it is usually better to replace the phone.
Was dit antwoord nuttig?
Score 2
Voeg je antwoord toe
Nir zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 162
