Ga door naar hoofdinhoud
The sixth-generation Honda Civic was introduced in 1995. It retained its class-leading handling as it, along with the fourth and fifth generations, had front double wishbone suspension, the advanced independent suspension inspired by Honda's racing research.
51 Vragen Bekijk alle
Engine code for Honda civic
What dose engine code d0135 mean for 1999 Honda Civic
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Het nuttigste antwoord
Joeb, never seen a D0135, only a P0135 which means "Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)" To repair that I would start by replacing the oxygen sensor as well as checking the wiring harness to make sure it is not damaged.
Was dit antwoord nuttig?
Score 1
I had quite an issue with my 1998 Honda Civic HX, told me the oxygen sensor was lazy, even for a new sensor. Turned out that the ECM needed more recent firmware, but an update was not possible. Ended up getting a replacement ECM which cured the problem.
Voeg je antwoord toe
Joeb zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 784
