Model A1312 / Mid 2010 / 3.2 GHz Core i3 or 2.8 & 3.6 GHz Core i5 or 2.93 GHz Core i7, ID iMac11,3
302 Vragen Bekijk alle
Want to upgrade i3 to an i7 CPU
Hi. I just got a used 27" 3.2 GHz i3 iMac. I'd like to upgrade to i7, is this possible cuz all these answers are from at least 3 yrs.
Btw, I'm using this for lightroom and autocad 3d and I don't speak computer.
Thanks
Vanessa
Is dit een goede vraag?
Commentaar:
Can you give us the last four digits of your serial number so we can correctly identify your system.
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100 of met een Pro Tech Toolkit!
Doorblader onze winkel
1 Antwoord
I recently upgraded from imac11,3 27" i3 (http://www.everymac.com/systems/apple/im...) to I7-870 CPU.
The things that I learned:
- You must choose exactly the same model of CPU: i7-870 for maximum compatibility
- With i3 CPU, max ram / slot = 4 GB. With i7, it can support 8 GB ram /slot.
- if you are dismantling the imac the first time, be prepare to spend 2-3 hours.
- be careful not to clean the memory slot - there are stories people pushed the memory slot pins and render it not usable.
- Unplug the power cord and let it sit for a few minutes for the electricity to discharge from the capacitor before removing the screen.
- it is possible to add a 7mm SSD and placed it underneath the DVD rom slot area. You will need a SATA power splitter and a SATA data cable.
Good luck!
Was dit antwoord nuttig?
Commentaar:
@Yusof - You could just use the spare SATA port if you are adding a drive Vs a splitter cable that way you get better data throughput.
door
Voeg je antwoord toe
Vanessa Alfa zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 0
Afgelopen 7 Dagen: 0
Afgelopen 30 Dagen: 0
Altijd: 87
