Ga door naar hoofdinhoud
Het Philips-model GC8220/02 is een stoomgenerator onder hoge druk die een afneembaar waterreservoir van 1,4 liter gebruikt voor het strijken en stomen van stoffen.
17 Vragen Bekijk alle
Why my steam iron can't get steam come out
The steam iron, I get the problem is steam don't came out...when I press the pressure button on the handle ,steam don't came out n the water still get boilling no steam out. How can I fix it?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Hello,
I would try using a 50/50 mixture of distilled water and vinegar. I use this mixture to clean my coffee pot and steam mop. 90% of the time it works everytime!
Was dit antwoord nuttig?
Score 3
Hello!
I just find some good web page. This problem is related to electronic, pump power supply.
https://lieven.kks36.be/2016/06/11/phili...
I hope it will help You.
Best regards!
Marin
2 opmerkingen:
How can I solve my steam generator problems, it do trip off if you pressed pressure bottom on the handle and steam doesn't come even after I cleaned it with 50/50 with white vinegar. Bello
door
Brilliant thank you. It's working now. 😁👏
door
Try opening cap where the water is topped up. If it starts to steam then, on my Philips Azur, there are two tiny pinholes in the cap which were blocked. A poke with a pin was enough to sort the problem. They allow air to enter as it steams, otherwise a vacum would occur and stop the water flowing.
Voeg je antwoord toe
phongtu008 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 10
Afgelopen 7 dagen: 77
Afgelopen 30 dagen: 452
Altijd: 68,078
