Ga door naar hoofdinhoud
Repair guides and support for your Apple Wireless Keyboard. Connect and command your Apple computer wirelessly.
Why "k" key doesn't function?
Hi, the "k" letter of my keyboard is dead, I tried connecting my keyboard to two different machines (Mac and Win) with the same results. I tried to take the key off and clean it, but nothing changed.
Any ideas??
Thanks
Is dit een goede vraag?
Score 5
2 opmerkingen
I have 3 original Apple wired keyboards all with a malfunctioning K key - typing anything with a "k" included needs visual check to ensure it appears... otherwise its repeated tapping to get a response.
door
Had the same problem with letter Y...if it' not a software issue like speech dictation or similar, or mechanical issue like spilled liquid try removing the cap of the letter than adjusting the rubber connector...than take a pointy object and try pushing the key and gently adjusting the rubber connector. It has worked for me
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Here's the only solution I could find to a single malfunctioning key on that particular keyboard: http://www.omninerd.com/articles/Apple_C...
Was dit antwoord nuttig?
Score 4
3 opmerkingen:
Thanks Mayer, I only press the k key, but nothing happen, upper o lower case is the same.
Thanks a lot
door
That site appears to have been hijacked.
door
Voeg je antwoord toe
mvmarroquin zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 10
Altijd: 18,750
