Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
431 Vragen Bekijk alle
Why wont my ps3 play discs?
my ps3 slim wasnt readin discs and when i lifeted it up i heard something moving. i took apart my ps3 blu ray drive and found a quarter in there. after putting it back together i tried playin a game and it still wont work
Is dit een goede vraag?
Score 3
1 Opmerking
Answer for Ps3 slim quarter problem, what has happen is the quarter has damage the blue ray & laser reader check out this link hope it will help you good luck. https://www.youtube.com/watch?v=4Uvm4W_r...
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Probably still a few pennies left lol.
In all seriousness, though, there is always the chance that there is more debris in there if a whole quarter made its way in there. The quarter might have also caused physical damage to the moving parts of your Playstation.
It's a pretty common PS3 issue for laser lenses to go bad as well, which would be characterized by the blue light on the front turning red when the machine tries to read a disc. Unfortunately, locating a replacement lens that isn't just a factory reject is a difficult task if you're not going directly through Sony.
Was dit antwoord nuttig?
Score 3
1 Opmerking:
Totally agree with this assessment. I love the ps3 but I've replaced 3 lenses in my own, without foreign debris causing them damage
door
I fix 200 ps3's a month. I see this ALL the time. If a coin has bounced around inside. You have the following possible problems.
A) Scratched Laser Lens
B) Broken Gear or Jammed from coin passing thru it.
C) Feed Gear Misaligned...
If you open the Blu ray drive..BE CAREFUL there are spring sin the drive that release the "Claws". Getting them back aligned is a pain in the arse.
Score 1
1 Opmerking:
Unfortunately learned that the hard way lol
door
Voeg je antwoord toe
buford zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 7,531
