Why can't I shift out o gear?
I have a first bike that has been in an accident with no apparent damage except to frame. I have good auto mechanical experience. None on Harleys.
The gear shift lever does not shift gears. Some thing is going on in the trans but no solid connections. No spring action on the lever. The bike is in gear and won't shift. What's broken?
Is there an online video or tutorial on inspecting for damage? I don't want to tear into something that requires special tools and equipment to result into taking a box of parts to a dealer.
Is dit een goede vraag?
mine sometimes sticks a bit until I pull the clutch in and start the engine, then it starts shifting again. I imagine that some combination of rocking it back and forth, pulling the clutch and generally jostling as much as possible might have the same effect.
door Noah Ackerman
