Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
Repair guides and support for your Samsung TV.
1887 Vragen Bekijk alle
My tv screen stays black when turned on but I have sound
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 18
Commentaar:
What model is your TV? What have you checked?
door
Samsung 46 inch Ln46d550 I read on opening TV and cutting a wire but not sure which on for this model.
door
I know this is a Samsung q/a board but there is no q/a for Emerson.
door
Hi @scottecamel,
If you post your 'comment' regarding the problem with your TV as a new question you will hopefully get helpful answers.
Have you got a DMM (Digital MultiMeter) at all? If so with the power cord disconnected from the wall outlet, using the DMM (Ohmmeter function) place the meter leads across the power cord pins (i.e. test back into the TV) and see if you get a reading at all. If not you can start tracing the power path (you should get a reading up to where the fuse is, as you said it was blown.
BTW here is some info regarding the TV
https://www.cnet.com/products/emerson-lc...
The quick and dirty way to possibly fix it given that the problem occurred after a power outage is to replace the power board and hope that the problem did not spread further than the power board and that the fuse and closely associated components bore the brunt of it..
Here is a link to just one supplier. Scroll down to find the board. There are other if you search online
door
I do have a DMM, but the cord doesn't unplug from the back of the TV like a Samsung does. It is connected inside the the cover.
door
7 commentaren meer tonen
Voeg een opmerking toe
SLA DE UPGRADE OVER
Bespaar door het te repareren met een alles-in-één kit.
Koop iPhone-reparatiekits
SLA DE UPGRADE OVER
2 Antwoorden
Gekozen oplossing
Sean colgan, it seems most likely that the problem is either the backlight or the power supply for it. Samsungs have a well-known issue with bad caps in the PSU section. Check those first. Of course you do want to make sure that your TV is unplugged. Leave it unplugged for a couple of hours (overnight) Of course you also want to try a different video source. More information when we know what model this is.
Check the diodes on the power supply. Those have a tendency of failing on this model.
Was dit antwoord nuttig?
Score 2
Commentaar:
I have the same problem (monitor goes black after 2 seconds, but the sound is still working). Could it also be the diodes?
Checked them and they seem to be okay.. However, I did see a small brown (looks burned) spot on the white side of the printboard. Right next to a diode.
Will investigate with a multimeter later today.
Edit: investigated the diode. Diode seems okay, the printplate however, the contacts of the diode are a little burned.
Should I change the diode and repair the back of the plate?
(Samsung P2770HD)
door
I have same no pic but sound,tv man looked at it and said there fault in the screen itself and said I would be out the price of a tv to fix it seem to me he wasnt bothered
door
noreenmercelle what model is your TV and do you know what has been checked? Does your screen show anything?
door
Maybe you got problem with your backlight. What tv you use? Led or Lcd? If you use Led tv mybe LED at the backlight is broken. Check your led with multimeter 1xohm. Detect which one not working and replace it. You can order your led at taobao.com
Score 1
Commentaar:
how do I check the back light
door
switch light of in sitting room if you do it at night get flash light put it in front of screen check all round screen to see if you see a pic thays how you lnow if its the bk light or not
door
i got the same problem but my TV is different model blaupunkt, i tried to put flash light as to see what is happening, yes there's a picture but its very dark you can't see without a flash.
door
Voeg je antwoord toe
Sean colgan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 23
Afgelopen 7 dagen: 233
Afgelopen 30 dagen: 1,044
Altijd: 51,998
