Ga door naar hoofdinhoud
Repair information and guides for the fifth generation of iPhone. Model: A1387
2191 Vragen Bekijk alle
Vraag afgerond
Water Damaged iPhone 4S Not Charging But Works
I have a water damaged iPhone 4S that works when I put a battery with charge in. However, when plugging into a power source; wall or PC, it does not charge, it shows the charging symbol, and iTunes can detect the phone, but the charge percentage doesn't rise, it only goes down. I have transplanted the board into a new chassis, to rule out dock connector, and used a known working battery, and it still doesn't charge. It has been a while since it was damaged, and I will try cleaning it today with some iso. If that fails, can anyone help me identify components of the charging circuit to be tested?
Thanks, Mike
EDIT:
I have also noticed that when the battery is disconnected, and plugged into a power source, the phone does not try to boot when trying to turn on. However when I try this with another 4S, it actually gets to the Apple logo before restarting.
So, maybe power is getting to the board, as it shows that it is charging, but the power is not getting to the battery, or the parts of the board that need it?
Is dit een goede vraag?
2 opmerkingen
1)connect the charger
2)remember the battery percentage
3)power off the phone (with charger connected)
4)wait half an hour
5)Power on
Now, did the percentage rise, or stay the same ?
door
Battery percentage did not go up. I have tried cleaning the board too with isopropyl. I'm running the latest iOS if that helps.
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
It's the charging coil. Replace it.
ON EDIT:
I realized after posting this might seem a bit abrupt. I've had this a half dozen times before with water damaged iPhone 4S's and it's always the charging coil.
I'm in the middle of some stuff though so I can't go into too much detail. If you google iPhone 4S charging coil repair or somesuch you'll find pics of the coil (under a shield) and lots of info about the repair. I think the Asian repairers call it "4S fake charging" what with the translation. So that's another google term.
Was dit antwoord nuttig?
Score 1
Het nuttigste antwoord
iphone 4S cant boot without a battery i believe. it might be possible that a circuit is damaged that provides charge to the battery.
Score 1
3 opmerkingen:
No it cant boot, but the my other 4S at least displays the Apple logo and tries to boot, whereas this one does absolutely nothing. I think a circuit has been damaged, I would like to try and repair it though.
door
ok go and see what part is damaged
door
Does anyone know which components need to be tested?
door
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 144
