WiFi iPhone 5 not working
I am measuring a short on antennae input on logic board without antennae.
does that mean 339s0171 is faulty and can it be replaced
Is dit een goede vraag?
Gilbert Bani
Yes. replace it
Was dit antwoord nuttig?
Um, how would I do that? does it pop out/in, or does it need soldering?
It's soldered on. Problem is that even if it was replaced it will also require getting the NAND flash memory chip (hard drive for example) to be reprogrammed with the new Wi-Fi chip's MAC address.
Without reprogram the replacement Wi-Fi chip won't work with the phone.
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 122
2 opmerkingen
You might have measured it wrong. Wifi antenna connector is grounded.
door ElBo
I'm not sure that you read my question.
I have the WIFI antenna disconnected with it disconnected the input to logic board or wifi antennae input is measuring 0 ohms.
Does this go to wifi chip 339s0171 directly or through some other interface. I cannot find any circuits.
door [deleted]
