Ga door naar hoofdinhoud
Repair and disassembly guides for the Compaq Presario CQ40.
30 Vragen Bekijk alle
The screen flickers and and works only at an acute angle.
The screen works only at a very acute angle, at 90 degrees or normal upright it's just black.
Is dit een goede vraag?
Score 3
Commentaar:
My pc screen flickers really bad I have to keep moving the screen to stop it flickingg any help would be much appreciated
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
This is a sign of a loose connection in the monitor. I had this issue with my old laptop, it kept flickering then eventually turn white unless at a certain angle. A little knock would change it white.
when it got repaired, it was because the connectors in the monitor was loose. So thats your best bet.
Please et me know if ive helped,
Ryan
Was dit antwoord nuttig?
Voeg je antwoord toe
lloydsimoes zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 1
Altijd: 628
