Ga door naar hoofdinhoud
Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3531 Vragen Bekijk alle
iPhone 5s wifi antenna
hi i got a iPhone 5s 16gb wifi is working ,got to be real near to my router only can connect with it within a range
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
2 Antwoorden
Try restoring first. Check if other devices do this too, then the wifi router might be the problem. If neither of those help, replace the wifi antenna. If none of those work, the logic board is broken.
Was dit antwoord nuttig?
I know this is a bit late! But, when replacing my 5S battery I broke the wifi antenna (I hadn't realised it initially). I could connect to wifi 5ghz but it was very intermittent and I couldn't get a stable connection plus the 2.5ghz connections just wouldn't work or accept a password. Replacing the Wifi antenna restored everything.
Voeg je antwoord toe
shiwan zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 1,084
