Ga door naar hoofdinhoud
Model A1051 / 4 of 6 GB harde schijf
89 Vragen Bekijk alle
Where I can buy new memory for my iPod?
(iPod Mini 2nd Gen)
What type of flash memory i have to use to replay my ipod's memory?
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Your iPod mini uses a micro hard drive. Here's the IFIXIT guide to replace it: iPod Mini Hard Drive Replacement. Here's the IFIXIT replacement part: iPod Mini 6 GB Hard Drive (Used). Here's the Microdrive spec sheet: Hitachi Microdrive CF+ Type II model.
iPod mini 6 GB Hard Drive Afbeelding
Product
$79.99
Was dit antwoord nuttig?
Score 2
You could also buy a Compact Flash (CF II type) to SD card adapter. Buy an SDXC card of whatever size you want, I have a 64 GB, 128 GB and a 256 GB in some of mine and you can go up to 512 GB. The cards has to be formatted to FAT 32. I formatted mine in a Sony Alpha 350 camera or any camera that takes CF cards but the SDXC card, on it's own, should format in an ordinary camera or on a computer. I fitted the CF adapter with all the sticky tape and blue plastic buffers but this really isn't necessary as the drive is now solid state and more robust. After rebuilding the Mini (put in a new battery if in doubt) connect to itunes and follow the reformatting menu that pops up and you should now have a more reliable, less battery hungry iPod mini.
Good Luck
Voeg je antwoord toe
max morelli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 167
