Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4547 Vragen Bekijk alle
Where is the memory card
Location of memory card
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 7
Commentaar:
good day guys I Have a concern my Iphone 6 is 64GB but they always said that my phone is not enough memory? so i can download the i want..
door
I have 6gb storage in my iPhone 6.How to increase it
door
I have 128 GB in my iPhone, but it's showing no space, can't help..!!!
door
Where is the iPhone memory card
door
Een opmerking toevoegen
Gratis verzending van alle bestellingen van meer dan US$ 100,00 of met een Pro Tech Toolkit!
Doorblader onze winkel
4 Antwoorden
Gekozen oplossing
here it is
Was dit antwoord nuttig?
Score 6
Commentaar:
There is no memory card inside iphones. apple use BGA chop to do all memory functions
door
Thanks. I had a water damaged iPhone 6 that carrier At&t wanted me to return to them and they said for my safety, to remove the SIM card (I did do that) and the memory card (I didn't do that because I couldn't find it). I assume there is no problem then, right?
door
No problem. That's way the Apple handling replacements
door
Hei buddika i am sri lankan and i want to contact u regarding a iphone problem is there a way i can contact you
door
Hello Nipuna, Welcome to ifixit, post your question here i'm happy to help you and here many professional volunteers who can help you to fix your phone yourself
door
9 commentaren meer tonen
Is it possible to switch memory card to a working logic board if my phone is dead and I need a backup
Score 1
Commentaar:
Flash module soldered to logic board and you will need high level BGA reworking skills to replace it, even if you replaced it you want be able to decrypt the encrypted data on dead. Simply, answer is NO
door
Simply answer is yes actually. The nand CPU and baseband use cryptographic paring, you would have to replace all 3.
door
Q. How can I even search for a place that would be able to replace the parts on a new board? My phone is smashed. Major damage. No power. But I think if I took to a cca house they could do it. I would pay. I just want my pictures and videos
door
were you able to recover your photos and videos? if so how'd you do it? My phone is in the same condition as you described yours to be. I too need to recover my photos /videos. Any suggestion you might have would help . Thank You
door
The memory card id inside the actual iPhone if you want to get a bigger one i recommend buy a new iPhone and don't struggle
Commentaar:
how can i expand my memory card?
door
How do you know if your phone is done for if it fell in water
door
iPhone does not have a memory card that you can change.
However, you can add expanded storage as a separate drive via the lightning dock.
https://www.sandisk.com/home/mobile-devi...
There is also an external SD Card reader available.
https://www.apple.com/shop/product/MJYT2...
Voeg je antwoord toe
Ruth Laug zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 28
Afgelopen 7 Dagen: 155
Afgelopen 30 Dagen: 772
Altijd: 59,484
