Ga door naar hoofdinhoud
In 2012, Sony Entertainment announced that the company would be releasing a new version of its 2006 Playstation 3 console. The new console is call the Playstation 3 Super Slim and is identified by the model number, CECH-4000. The PlayStation 3 Super Slim (CECH400x) is the third version of the PS3 video game console produced by Sony Computer Entertainment. It was released October 25, 2012.
210 Vragen Bekijk alle
Vraag afgerond
HDMI Port replacement for ps3 super slim
hello , my HDMI port out broken in my ps3 super slim i'm asking if it's the same other HDMI ports like TV cuz i'm gona try replace it and worry it's it's specific part
regards
Update
THESE ARE THE PHOTOS ,HOPE THEY CLEAR FOR YOU
Is dit een goede vraag?
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Serag Zwait, most likely not. There are even two different types of HDMI port used for the super slim. The only way to determine this is by physically looking at the ports and to compare them.
Was dit antwoord nuttig?
Score 2
5 opmerkingen:
thanks , i'm try to find replacement port to change , maybe got it new or used from broken tv
door
Not sure where you are located but you should be able to obtain a port that will definitely fit with relative ease. Post an image of the port so we can identify it as model A or B
door
ok i will check it and back to you and post photos ,
door
please check the comment bellow i attached picture with HDMI port of my PS3
door
Looks like a type B HDMI take another picture of the top part, just to make sure. Very, very unlikely that the one from your TV fits. If you have a pair of vernier calipers you can measure the pins and compare it with the one you have.
door
Since the replacement HDMI replacement female units are so inexpensive and yes it could be used in a number of products. If you are planning on returning soldering it back in. I would use a heat gun waving it back and forth over and over until the holes are all revealed and it will either fit in or not. Just use thick aluminum foil and insulate any rubber plastic ect. Also the four largest solider points just support the actual unit. That is the only worry I have since I am doing the same thing as you right now.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 4,469
