Ga door naar hoofdinhoud
The HP Photosmart Premium All-in-One printer can be used as a printer, copier, scanner. This printer uses a 5 color print system.
14 Vragen Bekijk alle
Vraag afgerond
How to fix external ink tank to this printer
i have this printer that i wont to give it external ink tank but i don't know how to do that, pl's help me fix this
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
Hey soul, Are you having trouble with your printer? Is there ink leaking in your printer? you can easily clean up the external ink tank of your printer man! Don’t worry I will help you with your problem. You need not send it out for any services centers. First open up the tray and remove the INK holder from the printer, Make sure you removed the inks. Now take a syringe with Iso-propyl alcohol clean the each section of the ink Holder then let leave it for 30 minutes then treat the holder with alcohol. Now dry it and then insert the ink and fix it back on the printer.
I think this would be helpful for you, if you have any queries or trouble with the HP printers visit https://www.123-hp-com-envy.com/hp-print... site or call their toll-free number. It really helped me. I have gone through this site it was really good. Try this for yourself.
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 352
