Ga door naar hoofdinhoud
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
630 Vragen Bekijk alle
Vraag afgerond
Power Flex does not work after Touchscreen replacement
Hi,
i replace the Touchscreen from my iPad Mini. Now the Powerflex does not work. Also the Button in Assistive Touch does not work.
New Power Flex, same problem.
When i press the Powerbutton longer, the button response and i can choose "iPad Shutdown"
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
That's actually a problem with the IC chip. Did your replacement digitizer come with the IC chip or did you solder it yourself?
Either way, the IC chip is your problem.
Good luck!
Was dit antwoord nuttig?
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 61
