Ga door naar hoofdinhoud
Repair guides and support for phones manufactured by Lenovo.
283 Vragen Bekijk alle
My power button is not working lenovo a7000
I have charged my phone overnight.In the morning i came to see that my power button is not working.Help me out
lenovo a7000
Is dit een goede vraag?
Score 15
3 opmerkingen
lenovo a7000 switch solution
door
my phone was not getting charged more than 15% and now it cant be switched on? plz help
door
What to do if lenevo 480060a2 on off button is not working . And if mobile phone get switch off
door
Voeg een opmerking toe
7 Antwoorden
Het nuttigste antwoord
Was dit antwoord nuttig?
Score 3
I faccing same problem
help to out me from this problem
Score 1
2 opmerkingen:
Facing same problem.
door
Turn on tap to wake from menu. that's how i bypassed the power button bullcrap.
door
1) Connect your phone to a computer using USB
2) Hold upper volume key for 5 seconds as soon as your phone is plugged in to a computer using USB cable.
3) A menu will appear. Use upper volume key and go to the 3rd option which is " boot normal"
4) Press lower volume key for selecting that option.
Your phone will be switched on automatically.
Score 1
Restart it just by adding the restart button in the notification panel when you slide down you'll see a 4 dot at the right side.
I have lenovo a7000 I charge phone at night next day phone is not switch on what should I do
Change Sleep option to ‘Never’ under settings, display option. Although this isnt a solution, may temporarily address the problem, at the cost of draining batter
My power button was broken
Voeg je antwoord toe
arjnkar zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 5
Altijd: 14,356
