Ga door naar hoofdinhoud
A laptop by Lenovo, commonly found in offices all over the world.
17 Vragen Bekijk alle
External Monitor Screen Flickering
Hi
I have a Lenovo Think Pad T410.
When I connect the laptop to an external monitor through a VGA cable,when you open a gray picture or a software with gray background,you will notice a huge noise on the screen,there are many websites that suggesting,this is all about ground loop,and you must cut the ground wire somehow,but the monitor power cable doesn't have any ground connection at all,and the charger ground pin,is not connect to the outlet.
So what is the problem exactly?
What is the solution?
Is dit een goede vraag?
Score 1
3 opmerkingen:
Does the external monitor work alright on another computer?
door
Yes,It's Quite OK.When I use another computer.
door
It's really weird,but I found the solution,I have stripped the cable and cut the shield around it,and the noise gone away,just a little bit of noise,so I have tried a cheap cable without an aluminum shield but only just a ferrite core,and the noise is gone now!!, I think the shield was playing as the noise carrier here,and the cheap cable solved the issue.
door
Voeg een opmerking toe
3 Antwoorden
Dear hbirjand.
They was talking about the ground wire which comes in VGA cable. try to do below steps and faults may solve,
1) Clean the VGA connectors and try to stable connection, as well as check whether broken or bent pins were in the male VGA connector.
2) Change the second monitor's Restoration to minimum level and try
3) Change the VGA cable and try
Was dit antwoord nuttig?
1 Opmerking:
Please read my new comment,under the question section and thank you.
door
There are 3 cause of this issue:
1- Group loop on your connector
2- VGA cable or VGA output port issue
3- VGA chipset issue
But the highest posibble option usually is frist
To fix this issue
1 - Follow this article to break the ground loop on your monitor and laptop connectors
https://mrgnome.wordpress.com/2009/06/12...
2- TESTED ON UBUNTU: If the above solution cant help, try to install TLP and reboot your ubuntu, the noise will be gone. To install TLP, follow this article
http://linrunner.de/en/tlp/docs/tlp-linu...
Good luck
Turn off the wireless network adaptor. That worked for me.
Voeg je antwoord toe
hbirjand zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 5
Afgelopen 30 dagen: 6
Altijd: 3,924
