Ga door naar hoofdinhoud
1.6, 1.8, or 2 GHz G5 processor
20 Vragen Bekijk alle
a little further now with my g5 17''
I had a bad cap under my power supply, which is now fixed.
I still can't get pass the grey screen with the apple logo.
I did the command,option,shift,delete trick and i got a folder with a flashing question mark(?)and that 2 faces thing.
can anybody tell me what's going on now?
Is dit een goede vraag?
Score -1
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
The question mark on start up means it can't find a system folder. It does not mean the hard drive is bad. The hard drive may have connection problems or a corrupted system, or the drive could be bad. Start up from a system installation disk, go to the second page, pull down menu and go to Utilities-> Disk Utliity and see if you can repair the drive. Then try restarting.
Was dit antwoord nuttig?
Score 2
3 opmerkingen:
Thank-you...
Where can i get this disk from,and how much does it cost?
door
Good answer +
door
Voeg je antwoord toe
david blacks zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 0
Altijd: 766
