Ga door naar hoofdinhoud
Google-branded tablet with a 7" screen. The device needs only prying tools and screwdrivers to fix. Model number: ME370T.
149 Vragen Bekijk alle
cannot get on broadband other devices ok
Nexus 7 2013 tablet 7" cannot get on line says incognito how do I free it.
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Go to Settings > Wi-Fi > Select your network from the list > Tap it then hit Forget.
Check That your mobile operator is listed
Ensure that you're at a location with Mobile Broadband/ Home Wireless Broadband coverage. You can check coverage at your address .You must be in a 4G Plus or 3G dual band coverage area to access the Mobile Broadband network.
Ensure that your Mobile Broadband/ Home Wireless Broadband SIM card is activated
On some devices having Wi-Fi and/ or Bluetooth activated can override a successful 'Cellular' connection to the internet.
If you're able to, switch Wi-Fi and Bluetooth off on your computer/ tablet and try to access the internet via your Mobile Broadband /Home Wireless Broadband service.
If you’ve tried all of the above and you still can’t connect to Wi-Fi, then further investigation is needed.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
It was helpful but I am still having prblems. Further investigation required
door
Voeg je antwoord toe
Ann Davies zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 3
Altijd: 82
