I've got vertical lines on my iMac 27" screen
After I opened it to replace the HDD I got vertical lines, after return from an authorized Apple they return even more problematic, they said that the LCD was damaged, but I just open as I do always, I thought that is the cable/connector.
Has anybody pass thought the same problem?
Update
Here the screen photo
Is dit een goede vraag?
3 opmerkingen
Sounds like a TAB error. Post an image of what your screen looks like with your question for confirmation.
door oldturkey03
iMac 27" i7 3.4 GHz (Late 2012)
door Dan
If the lines disappear when you apply pressure on the upper vertical edge of the LCD, where the tabs are bonded, you know that the bond has failed. There is really not much of an DIY fix for it.
door oldturkey03
