Ga door naar hoofdinhoud
My Tablet just stopped working . will not allow charging
Tablet has turned off and will not boot up via charger. The table is several years old could it be the battery and can it be replaced?
Beantwoord! View the answer Dit probleem heb ik ook
Is dit een goede vraag?
Score 11
Commentaar:
how to change battery...open tablet case
door
Een opmerking toevoegen
4 Antwoorden
Gekozen oplossing
Try connecting it to different power sources and see if you're able to get any activity to show on the screen. Do you see any status lights or icons on the screen when you plug it in?
Was dit antwoord nuttig?
Score 3
Commentaar:
On my tablet it does a battery icon
door
I love my samsung tablet & I've only had it seven months. All of a sudden it won't charge. I've tried different chargers. It doesn't help. I can't even get the back off to look at battery. Very frustrating & no clue what to do.
door
Have the very same problem..waiting for an answer. Let's hope we get one.
door
Thanks for this, been a while since we could afford a new device so this article really helped us save a few $$$. Thanks!
door
Open your Tab, remove small black plug leave it off for 10-15 sec.
Attatch it again. close Tablet and start charging.
Remember not to drain your battery hereafter, otherwise you have to do this operation each and every time.
Se tube vid here.
https://www.youtube.com/watch?v=gMTp2BIx...
Ronny
door
Hello. It could be one of three things that is causing your Galaxy Tab 2 10.1 to no longer be able to charge. Those three things are the charger, the charging port being faulty or it needs a new battery (most likely). You can rule out the charger by purchasing another one and trying it with your tablet. I did a quick search and and you can find one for less than $5 on various sites like ebay/amazon. Here is a link to one on ebay selling for about $4 with shipping:
Samung Galaxy Tab 2 10.1 Charging Cable
Due to the age of the tablet (about 3 years old) the second and most likely thing that is causing this charging issue is the battery needs to be replaced. Here is a link to a replacement battery for the Galaxy Tab 2 10.1 for less than $30 and it also includes all of the necessary tools to open up your tablet and replace the battery yourself:
Replacement Battery for Galaxy Tab 2 10.1
Ifixit.com has lots of awesome galaxy tab repair guides but not for the Galaxy tab 2 10.1 specifically as of yet. Here is a link to another repair guide on the same site as the battery listed above:
Battery Replacement Guide for Galaxy Tab 2 10.1
If it is not the charger or the battery it is possible that the charging port has become faulty (least likely scenario). This can be diagnosed by a local electronics repair shop or you can purchase a new port flex cable and replace it while replacing the battery. It can be found on sites like ebay for less than $10. Hope this helps!
Score 2
Commentaar:
I have a galaxy 8 which just shut down even though there was battery life. I can't restart it or charge it. It's a few years old now. Any advice please?
door
My galaxy tab S 10.5 had wi-fi stop conecting then wouldn't charge. Sent g or repair and they said software fault likely cause and hage had 5 sent in with charging fault. Trying to find an answer.
door
I had same issue, with one of my samsung tablets.
I found out that if i open up then tablet, disconnect the small battery cable for 10-15 sec, re-attatche the cable, the problem is solved. And i can charge again.
Just making sure NEVER to let the tablet completly loos power, always make sure that there is power on battery.
But much better to replace the battery.
Score 2
Commentaar:
My tablet is 4 months old. Bought it brand new from at&t won't charge . Doesn't work. Gonna try opening and disconnect for 15 seconds then reconmect.
door
how to change battery on tab 7
door
I have the same problem. Good charger, new battery and charge port. Works great unless my wife runs the battery down. Random actions led me to open it up and unplug the battery and plug it back. And it worked! Have had to do that twice now when battery runs completely out. Didn't used to do that when it was newer though, so something is still amiss.
Commentaar:
how do you
open the back
door
Voeg je antwoord toe
JoAnn Heil zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 Uren: 11
Afgelopen 7 Dagen: 68
Afgelopen 30 Dagen: 390
Altijd: 23,335
