Ga door naar hoofdinhoud
The Huawei Ascend P7 is a 5" smartphone released by Huawei in June of 2014. Model numbers: P7-L10, P7-L00.
20 Vragen Bekijk alle
No Service No network
Hello.
My phone has been off for 2 days, fully charged it. and when i switch it on it ready no service... Cannot make calls nothing. Re-started still noting did Factory reset.. Still nothing.
Please help!!!
Thanks
Is dit een goede vraag?
Score 57
9 opmerkingen
My phones signal is gone for a while now
door
my mate7 has 1 month no signal, please help.
door
My Huawei honor p7i network is nt working please how do I do please help me out
door
My huawei phone is falling in the "no service "
How to relieve this
door
I just order a huawei honour 5 I install a sim but no signals
door
4 commentaren meer tonen
Voeg een opmerking toe
30 Antwoorden
Het nuttigste antwoord
1) check the SIM card is working properly
2) Check with your operator whether your IMEI blacklisted or not
3) update the firmware if available via OTA
4) Change the network mode : GSM only if signal comes change the network mode to 3G only if you found same issue the one of transceiver not working properly
Was dit antwoord nuttig?
Score 14
5 opmerkingen:
It wasnt helpful but the tranciever bit how do I fix it myself
door
How you did that my honor 9 its the some problem pleas
door
i have huawei honor 5x..sim its ok can detect,no problem..but signal no services..why yaa.. plis help me..
door
Sir
My mobile can not show the Sim he show no service plz help me my mobile y 7 prime 2019
door
I'm using Huawei Y5 2019 I've been struggling with network problems, it says cellular network is unavailable, try using wireless network to make a call
door
huawei p7 wifi not working
Score 5
3 opmerkingen:
Huawei p6 mobile network not working
door
Does your sims cards working please
door
I have Huawei y7 had network issues, I could not access internet, I just removed data saver and I was back,what I don't understand out of nowhere my phone started to have irritating issues NO NETWORK, I hope the magic works on you, next time I will definitely get another brand, I tend to believe Huawei phones are not reliable to its users
door
Score 5
1 Opmerking:
vai no Service network my mobile huawei scl-u31
door
mobile network not available in huawei mobile
i have huawei honor 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Network options is also missing in phone now.
Please help me. i just bought few days before.
i am very Sad :(
should i sale it :(
Score 3
1 Opmerking:
Same problem huawei p8lite
door
I have a Huawei Ascend phone. was on a call yesterday and reception cut out no reception since in christchurch nz middle of the city!
Score 2
Huawei Ascend G700 no network
Score 1
i have huawei honour 4C . It dipped into water at night and i did not care in night. When i open it in morning sim jackets have water drops. I removed water drops. Mobile is working properly but not the sim card. When i reinsert sim it says mobile network not available. I did factory rest but in vein.
Score 1
Huaweiy330-u11 when inserted SIM it say emergencycall how to fix this problem ?
Score 1
Try to turn on airplane mode, then turn it off. It helps me when i lose network signal
Score 1
Network wcdma not work
Score 1
how can i do how can ido
Score 1
Huawei p20 lite no service
Score 1
Huawei Mobile IC network is default
Score 1
i got lycamobile sim card
when i put in on my phone called huawei p6
and when i want call some in said no service but for anther phone he does work but on huawei not why please help
what can i do make it work
huawei p8 lite no net appear after ten days i try all options no hope
1 Opmerking:
no net work shown i restart many times i remove sim many times ...still the same pls your help it's ten days back parched >>
door
no service max mobile 424 model
My sim app is no long in my huawei so I don't have any sim setting it says only emergency calls only and I don't have any network show in my phone ?
How to set Sim menagement?
I Have This Problem Too
honor v9 no service how to this problam fix
Remove sim n put it back.
try hard reset if nothing's happen is the problem of your cellphone is crystal ic or antenna
Falling in water and when on then no service its taking Sim but no signal
1 Opmerking:
i have this problem too
door
How do I get my new handset working it isn’t reading
Update (04/06/2019)
I just brought a phone it’s not reading my network or service rovider
Mate 20 lite Huawei no service :'( android 9.1.0.225
my huawei 3i fall into water when it fix it comes another problem no service appears i can't use it anymore i tried all the recommended steps but it didn't work please help
how to fix no service for huawei y7 prime 2019
2 opmerkingen:
please help me with this
door
to my email yasirbofa@gmail.com
door
Network is not working
When my phone is no service Huawei nova 8i how can i do?.
How can i do about myself
Voeg je antwoord toe
muzithembekwayo88 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 21
Afgelopen 30 dagen: 53
Altijd: 114,799
