Ga door naar hoofdinhoud
Samsung's second-generation smartwatch, released in April 2014 and powered by a Tizen-based OS. Model Number:SM-R380.
parts needed, where to buy, gear 2 backing and neo speaker
I am looking for somewhere to buy parts as I have two samsung gears one is the gear 2 and the other is a gear 2 neo. the neo needs a new speaker and the gear 2 needs a new backing as the one of the charging pins has broken off.
Is dit een goede vraag?
Score 3
1 Opmerking
Hi was my answer helpful? do you need any more help?
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
there is no where that sells parts for the samsung gear that i know of.
the best thing to do is buy broken ones off ebay and strip them down for parts.
and if you don't have any moral decency, you can reassemble the broken ones and send them back to seller as original condition.
Was dit antwoord nuttig?
Score 1
I'm looking for the display assembly (the upper part) my screen is only lines. I found it for only $29.99 if you are willing to part with your? My watch Works it just doesn't have a good display.
www.rounded.com have a lot of spare part for the gear 2 neo
I am looking for Samsung gear neo 2 part to buy in Ghana, as am having problem with the charging connector.
1 Opmerking:
I bought a connector off amazon (Kingboxs Charger Charging Connector for Samsung Gear 2 SM-R380 Gear 2 Neo SM-R381) 8.99 us.
door
Voeg je antwoord toe
ve3rma zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 8
Altijd: 1,173
