Ga door naar hoofdinhoud
Released Spring 2015 RCA 7-in 8GB Adroid 4.2 Tablet
25 Vragen Bekijk alle
What do I do if the battery explodes?
After use, the device battery has puffed up like a bag of popcorn, and I am unsure if it can be repaired or will need to be replaced.
Is dit een goede vraag?
Score 2
1 Opmerking
Take the battery out
door
Voeg een opmerking toe
2 Antwoorden
Gekozen oplossing
Exploding battery is a common problem associated with the device. If you notice bulging in the back of the device indicating the battery has expanded, or the battery has exploded entirely it is necessary to replace the battery for continued use. See Battery Replacement Guide for replacement instructions.
Was dit antwoord nuttig?
Score 2
If its just the battery it can be replace with the mother board. My friend took out the battery an replaced it with a new mother board and battery it works just fine now
1 Opmerking:
Teishka Candelario why would you suggest to replace the motherboard? The device definitely needs a new battery but not sure why you think it would need a motherboard.
door
Voeg je antwoord toe
Kirby C zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 4
Altijd: 1,456
