Ga door naar hoofdinhoud
Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
376 Vragen Bekijk alle
WD MyPassport external hard drive won't mount to my MacBook Pro
When I plug my external hard drive into my MacBook it flashes its white light and begins to stay solid, but doesn't show up on my desktop. I opened up disk utility and it said it was not mounted. I tried to repair the disk, but I got an error: File system verify or repair failed. Is there anything I can do?
Is dit een goede vraag?
Score 4
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Most of these drives can be changed to another external enclosure. I would get one that is self powered rather than USB pot powered.
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
So I should get a self powered external, and then back up my external that I have now on the self powered one?
door
You can try that or just get an external enclosure, transfer the hard drive and see if it works. That failing, drop a new drive in the new and/or old enclosures.
door
Hi, i have the exact same problem on a wd my passport 2tb drive formatted in hfs + (for mac). The wierd thing is that it mounts on windows 7 via bootcamp and paragon hfs + for windows ... So i think the problem comes from os x (yosemite for me) and i dont wanna reinstall everything.
I plugged the WD My Passport Ultra into my Window 8.* laptop and pulled up Windows Disk Management to ensure I had exFAT formatting and that the partition was ACTIVE. Corrected both, did a safe eject and plugged it back into the MacBook Pro and OSX 10.10 now mounts the drive. It works, try it.
use disk utility. erase the drive
Voeg je antwoord toe
Bryan Harris zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 1
Afgelopen 7 dagen: 6
Afgelopen 30 dagen: 13
Altijd: 7,105
