Ga door naar hoofdinhoud
iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
467 Vragen Bekijk alle
My 1tb hard rive in my 27" late 2009 iMac makes sounds and doesn't run
It makes a beeping sound when it gets turned on. Also it doesn't recognize that there even is a hardrive. The computer doesn't even load up anything.
Link To See What It Sounds Like: https://youtu.be/tRDi5jNTjds
Is dit een goede vraag?
2 opmerkingen
Can you give us the last four digits of your serial number. You'll find it on the bottom of the systems foot. That way we can guide you the reset of the way and aim you to the best drive for your system.
door
the recall on the 1TB Seagate ended 4/2013: http://9to5mac.com/2012/10/19/apple-send...
door
Voeg een opmerking toe
1 Antwoord
Gekozen oplossing
Ah... The ticking Time Bomb problem! Sadly, your drive has bit the dust here, its time for a new drive.
Was dit antwoord nuttig?
Score 2
2 opmerkingen:
This may be one with the proprietary sensor cable, so check before just ordering any drive.
door
Thanks Mayer! Forgot to point that out - So true! If you do want to switch to a different drive make you can! But, you will need to swap out the sensor cable to the correct one for the drive you are putting in.
door
Voeg je antwoord toe
alexab9909 zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 12
Altijd: 150
