Ga door naar hoofdinhoud
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Vragen Bekijk alle
Broken lcd ribbon vs logic board damage
I switched out the battery on my iPhone 5 today and everything worked when I put the phone back together. I then noticed that the top part was not fully flush with the phone, so I opened it back up and put it back flush. During this process I must have damaged something because now there's no image on the screen except white lines and boxes. I can still turn the phone on and hear the phone ringing when I call it. Should I bother buying a replacement LCD or should I just right it off as loss?
Is dit een goede vraag?
Voeg een opmerking toe
3 Antwoorden
Gekozen oplossing
Dave, clean those connectors with a cotton swab dipped in 90%+ isopropyl alcohol, or simply brush it lightly using a dry soft tooth brush, then take a new photo. I believe the board connectors themselves are not damaged and there is some residue on that connector.
Was dit antwoord nuttig?
Score 1
1 Opmerking:
Thanks for the suggestion Rany. I've cleaned it as you've suggested and I think you're right--the markings were just residue (http://cdn.img42.com/31842ed4d3c80e517b9...). So it looks like the connectors are intact. Might just gamble and get a new LCD assembly to see if it'll work.
door
Het nuttigste antwoord
May need a new screen. But first step, would be to open iPhone again, and carefully reconnect the screen flex connectors perfectly. If still problem, get new screen.
Score 2
2 opmerkingen:
Thanks for the quick reply! I've reseated it already and no still didn't work. I don't mind buying a new screen, but I'm worried that I've actually messed up the board, in which case I'm just throwing good money after bad. Is there a way to tell if the board is ok?
door
Call a local shop and ask if they have a cracked screen with working LCD that you could test for a moment.
door
You can't have seriously messed up the board from this, worst case scenario is just LCD connector damage--a board repair that costs about the same as a screen.
Most likely case--you have damaged one of the flexes on your screen. It is not a backlight problem if you can see some lines on your screen, so this is almost certainly screen damage. The only other choice is damage to the connector itself which you should be able to if you look very hard.
show us a picture of your connectors on the board and we can tell you
jessa
Score 1
3 opmerkingen:
Thank you Jessa. Here's an image of the connectors (http://cdn.img42.com/1926cf9b195249c2ab2...). It does look like one of the connectors is damaged, but if I'm not mistaken, that's the front facing camera connector--shouldn't affect the image, right?
door
door
Connectors are fine, likely screen defect. But that area was quite dirty so you might want to peel off that black sticker and clean under it.
door
Voeg je antwoord toe
Dave zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 173
