Ga door naar hoofdinhoud
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
96 Vragen Bekijk alle
Why is my battery not holding a charge?
After a full charge, the device will only stay on for an hour or two.
Is dit een goede vraag?
Score 11
1 Opmerking
my nextbook wont comeon at all
door
Voeg een opmerking toe
4 Antwoorden
Het nuttigste antwoord
Be sure you are using the charger that was provided from the manufacturer. Generic chargers tend not to charge the device properly and may kill the battery cells.
If you are using the appropriate charger, and your nextbook is still not holding a charge, it is likely that your battery is dead and you will need to buy a replacement.
Was dit antwoord nuttig?
Score 8
4 opmerkingen:
So what battery do we buy & where are the guides on how to do this ?
I have the same problem, I need a new battery.
door
please give me something to do
door
Charger will not charge battery give help on what to do
door
Well we have to use a 5 volt battery charger what we do then
door
Well we have to use a 5 volt batterywhat do we do then
Score 2
How old is the battery?
Over time, rechargeable batteries lose their ability to hold a charge.
It might just be time to replace the battery.
Score 1
Where done I get a battery.
Score 1
Voeg je antwoord toe
Zeke zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 2
Afgelopen 30 dagen: 6
Altijd: 2,752
