Ga door naar hoofdinhoud
Model A1369, 1.6, 1.7, or 1.8 GHz Processor, 64, 128 or 256GB Flash Storage
328 Vragen Bekijk alle
Changed wifi airport adapter - hardware not installed
Hi,
My macbook was working fine until i dropped water at him.
I dried all computer and turned on. Everything were working well, except the wifi that are showing the message: "No hardware Installed."
I tought weird, because bluetooth was still working, but wifi doesn't.
Even that, i bought an airport adapter and installed. But the message still there: "No hardware installed".
What could be the problem? What can i do to solve that?
Best regards!
Is dit een goede vraag?
Score 1
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
If you got a new Airport card and still are having issues, the connector on the motherboard may have been damaged. I would check the 'About the Mac' window and look at the system report to see if the system detects an airport card. If not, you could try an OS X restore. Otherwise, this issue is hard to fix...
Was dit antwoord nuttig?
Score 1
2 opmerkingen:
Hello Jake,
I've tried many ways to fix, but the solution was clean the contact of airport and re-install it. That works fine. Thank you for your answer.
door
Glad to hear it it working again. I would've never thought to clean the contacts.
door
Voeg je antwoord toe
Rafael Poli zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 247
