Ga door naar hoofdinhoud
Repareer je spullen
Recht op reparatie
Winkel
The second iteration of Samsung Galaxy Tab tablet computers with a 7.0-inch screen. Model numbers: GT-P3105, GT-P3100, and GT-P3105.
146 Vragen Bekijk alle
Battery indicator is malfunctioning please help
actually i bought samsung galaxy tab 2 model GT p 3110 about a year ago. Since the last few months it has got some problem . Actually if the tab is not charging, the battery indicator shows tha the tab is charging and makes it upto 100% after that it suddenly comes to 1%. Please give a solution for it.
Is dit een goede vraag?
Voeg een opmerking toe
1 Antwoord
How long is it running at 1% & does it automatically shut down at that point ? The lithium batteries have a built in chip that communicates the estimated battery level to the device. Most often devices are charged before the battery is discharged, needing only a top off to 100%. The chip needs to be recalibrated occasionally. Usually letting it run down until the device automatically shuts off & then recharging the battery to 100% is sufficient, but that has to be a single session for the chip to recalibrate. See if that helps
Cheers
Was dit antwoord nuttig?
Voeg je antwoord toe
Harshit zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 6
Altijd: 473
