Ga door naar hoofdinhoud
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 Vragen Bekijk alle
I can't charge my iPad
When I connect the iPad to the power adapter it appears the green battery with the lightning mark but the i pad won't charge
I tried the restor
I tried another power adapter
I tried another cable
I tried hold the two buttons
But the issue wasn't solved
Is dit een goede vraag?
Score 3
1 Opmerking
does the cable go in far enough inside the dock?
door
Voeg een opmerking toe
1 Antwoord
Het nuttigste antwoord
Firstly,iPad Air Battery is particularly sensitive to temperature, There are a lot of friends would like to protect it with the Case. But when the weather is hot in the summer, may it will lead to dissipating heat is not good and it failure. So please take it out.
Was dit antwoord nuttig?
Score 1
Voeg je antwoord toe
Sohaib Khelfi zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 2
Altijd: 1,178
