Ga door naar hoofdinhoud
This all purpose Android tablet was released in May 2013. It features a 7" 800x480 LCD screen, dual-core processing, and supports up to 32GB of additional memory.
Why do I hear a buzzing noise?
Whenever I use my earphones with this tablet I hear a constant buzzing noise coming out of the right speaker. It is fairly faint but loud enough to be an annoyance. I have tried changing the audio file numerous times but the problem still persists. Thanks in advance for any response.
Is dit een goede vraag?
Score 1
1 Opmerking:
Try using a more decent earphone.(expensive one).
door
Voeg een opmerking toe
1 Antwoord
One possibility could be that the device is not the problem here; the headphones you are using could also be at fault. Try using a different pair of headphones to see if the problem still persists.
Be sure to check out the Troubleshooting page for more information.
Was dit antwoord nuttig?
Voeg je antwoord toe
Antoninus Lamptey zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 3
Altijd: 206
