Ga door naar hoofdinhoud
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 Vragen Bekijk alle
broke the power button flex cable
hi,
i snapped the thin flex cable for the power button when trying to replace the screen. is there a part i can replace? or will soldering work?
Is dit een goede vraag?
Score 3
1 Opmerking
I have this same issue. I have ordered a replacement cable. Does it require soldering or will it just clip into place?
door
Voeg een opmerking toe
3 Antwoorden
Het nuttigste antwoord
Soldering skills of medium level will be required and a good iron with small tip (silver bearing (preferred) solder with good non acid flux as well). I would not advise anyone who does not have those skills to attempt repair unless you don't mind F@i& up the whole board. The ribbon can be bought online but it does require soldering.
Was dit antwoord nuttig?
Score 3
oneplus one power flex cable
http://www.aliexpress.com/store/product/...
Score 1
I did the same thing so I would be interested if you found a workaround
Voeg je antwoord toe
Damon zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 0
Afgelopen 30 dagen: 1
Altijd: 2,636
