Ga door naar hoofdinhoud
The Lenovo A7 tablet is a 7-inch Android tablet released by Lenovo in April 2015. The A7-30 tablet was released in two versions, the 3G/Wi-Fi model (MediaTek MT8382M) version, and the Wi-Fi only (MediaTek MT8127) version.
33 Vragen Bekijk alle
Why won't my Lenovo A7-40 power on?
it was fully charged n it just stopped working and wont on
its been 3 days and it wont get on i tried charging it but it wont get charged
Is dit een goede vraag?
Score 13
3 opmerkingen
I have a tablet and it turns on and you can hear everything but you can't see anything
door
I have this problem
door
my lenovo won t open
door
Voeg een opmerking toe
6 Antwoorden
Het nuttigste antwoord
If it does turn on it pops up Reboot and some other stuff too
Was dit antwoord nuttig?
Score 1
lenovo tab not turning on
Score 1
Guys Just press reset button and then press power button..if you cant find the reset button just open the back cover en then you can press it with finger... Good luck
Score 1
Check the battery. I opened mine and the battery didn“t charge anymore
Score 1
I had such a problem
The battery just had been moved
I put it right and labeled it
It worked
If you can feel the motor is buzzing, try to check the lcd cable, many lcd cable faulty in this device, that`s my experience, or try to disconnect and put it back. If it`s not charging can be charging port issue or battery even motherboard. try to factory reset with the power button and the volume up button.
Voeg je antwoord toe
sandy zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 1
Afgelopen 30 dagen: 8
Altijd: 3,275
