Ga door naar hoofdinhoud
The PlayStation 3 Slim is the second version of the PS3 video game console with the original model number CECH-2000. Produced by Sony Computer Entertainment it fixed many issues of the original (fat) Playstation 3. It was released on September 1, 2009.
465 Vragen Bekijk alle
My PS3 CECH-2501a won't power on after cleaning?
I opened up my PS3 after several years of use and went about cleaning it. After reassembling it, and double checking the wires and connections as I went, I plugged it back in. The red light indicating it was receiving power turned on but when I went to turn the PS3 on it flickered to green and then shut off completely. A couple attempts to find the source of the problem later I've given up temporarily until I can get some help.
Is dit een goede vraag?
Score 2
Voeg een opmerking toe
2 Antwoorden
strange , sounds like the yellow ring of death . But this is usually caused because of overheating. if all cables are connected properly then i would think it would be a yellow ring of death issue. Check this video for more info. https://www.youtube.com/watch?v=uMG-6rba...
Was dit antwoord nuttig?
2 opmerkingen:
I don't think so... It worked just fine previous to opening it up.
door
It also never displays a yellow light, or goes to a red blinking light. It simply goes from the red "Powered but not on" light to green "Powered and on" and then cuts off completely, no lights. I *think* it might be a psu problem...
door
I was having the same exact problem man I took it back apart and started inspecting the power unit and if you look where the prongs go in there's really nowhere for the dust that you blow out to go to so you have to manually clean that part and the prongs but of course be careful while doing so. I dont know if it is this way on yours but one of my long screws werent lining up right and if it was in, the problem remained, I left It out and it works great again. fixed it for me and my problem was identical to yours.
1 Opmerking:
I know its a little late for him but I figured I'd give a little back to the internet that I get so much from lol
door
Voeg je antwoord toe
selonianth zal eeuwig dankbaar zijn.
Weergavestatistieken:
Afgelopen 24 uren: 0
Afgelopen 7 dagen: 4
Afgelopen 30 dagen: 20
Altijd: 2,517
